Gentlemen,
Conventional wisdom suggests that tack welding the oil pickup tube to the pump body is cheap insurance. Can someone suggest the best method? I have access to a gas torch and a mig welder. Is brazing a better choice for the dissimilar metals? The pump and pickup are both new. The tube tapped in perfectly with the use of a home-made pipe driver.
Thank you,
Mike
Thank you,
Mike
