If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Hi
I did something stupid, I hooked up my battery cables backwards and polarized my electrical system and the gauges are pinned to the right. I hear there is a way to reverse it. Can anyone help?
Thanks Tony
Connect the battery correctly and try starting the car. Often, 'pegged' gauges, if not internally damaged, will self-correct. Also, the movement in these gauges is typically a needle bearing (vs. jewel or ball bearing) and when pushed beyond its dynamic limit will 'hang' in that position from simple friction.
GENTLY rapping/tapping on the case of a 'hung' gauge will free the point needle on its needle bearing and the correct electro-magnetic bias of the car running will put 'er back into action again.
BUT, this isn't a guarantee that you haven't 'fried' this/that gauge or that a given gauge is hung so badly that you're going to have to remove it and manually push the pointer back to it's normal position...
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
