I will be replacing the rear shocks with 2 AC Delco 88945172 which is the current available replacement for a 73 non heavy duty susp. In assembling the parts, will I need to order the lower shock rubber grommets or do they come with the shock? Also will I need the metal grommets that go between the rubber and the nut? Is it a good idea to replace all the hardware upper and lower ie bolts,nuts ?
Before I put them on I had considered painting them gm shock gray. As far as judging goes would the deduction be less if painted than if left black? Has anyone sourced rattle can gray from anyone other than Qanta or other mail order vendor? On the paint issue I was trying to save mail order and buy it local. Any prep tips if I do paint them? Thanks for the help. Proper prior planning and all.
