It's been a long time, and I can't remember if when gravity bleeding brakes, does one leave the brake pedal in the up (unapplied) position or should it be held down (applied) with a weight or some sort or a telescoping rod wedged against the floor or seat to hold it in the applied position? Then when you open the bleeders, it will gravity bleed. Saw an old time mechanic who always worked alone, do it this way but can't remember the pedal position.
Thank you,
Kurt #26406
Thank you,
Kurt #26406
