C2-Heater - NCRS Discussion Boards
C2-Heater
  • Dave C.
    • March 1, 2004
    • 82
    C2-Heater
    I just started smelling a sweet smell in the car and sure enough there is a leak in the heater box and antifreze is dripping onto the passenger side floor. How difficult is it to replace the core? I have basic mechanic knowledge but don't want to get in over my head. Does it come out from inside the car or in the engine compartment?
  • Mike M.
    • May 31, 1974
    • 8365
    Re: C2-Heater
    i assume its not an air conditioned c-2, in which case you ought to be able to remove the heater box , from inside the car, then disasemble it to get at the heater core which should be replaced or re-cored at your local radiator shop. mike
    • Dave C.
      • March 1, 2004
      • 82
      Re: C2-Heater
      Mike,
      ok, does the glove box need to come out?
      • Mike M.
        • May 31, 1974
        • 8365
        Re: C2-Heater
        yes, it makes access much better. radio also comes out to access the speed nut in about the center of the firewall.do you have the shop manual? mike
        • Rob A.
          • December 1, 1991
          • 2126
          Re: C2-Heater
          If you have, or can get a '66 Chevrolet Chassis Service Manual, the instructions for changing the core are very helpful. You'd be surprised how much a corvette shop will charge to do it.
