C2 '66 Jack handle - 1 or 3 hole? - NCRS Discussion Boards
  • Mark P.
    • July 31, 2003
    • 407
    I've got a late 1966 car and the info in catalogs and the JG do not match. The JG says 3 hole and the catalogs say 1 hole for a 66. Which is it?
    Thanks for the help!
    Mark
  • Rob A.
    • December 1, 1991
    • 2126
    Re: C2 '66 Jack handle - 1 or 3 hole?
    Mark,
    From every original '66 and '67 handle I've seen, definately 3 holes.
    • Mark P.
      • July 31, 2003
      • 407
      Rob,
      Usually I trust the JG, but it has been wrong before....
      Thanks for the clarification!
      Mark
      • Philip C.
        • December 1, 1984
        • 1117
        Re: C2 '66 I think one hole
        Mark The JG also says ex. manifolds are NOT painted on small blocks! I dont see the manifolds in the aim, so they must have been on the engine as an assembly. What do you think. Phil 8063
          Phil -
          The process at Flint Engine changed in late '64 or early '65 to install the exhaust manifolds after the paint booth; prior to that, they were in place when the engine was painted.
          • Wayne M.
            • March 1, 1980
            • 6414
            What doess the AIM state ?
            I only have the '65 AIM and TIM & JG, but Nolands's Vol 2 (pg.400) says that '63 thru early (Sept)'65 (wrench # 3780737) had no holes in the handle; then later '65 thru '66, # 3958953 had a single hole on the top.
            In '67, wrench changed to # 3898172 and had an additional 2 holes on the side of the handle. I don't know if the '66 and '67 NCRS Tech Manuals agree with these changes and timelines.
            • Philip C.
              • December 1, 1984
              • 1117
              Re:Flint process
              Hi John if thats true why does the JG for 65 have them as painted, and where did you get that info? are 67 also not painted Thanks Phil 8063
                Re:Flint process
                Phil -
                '67 SB are not to be painted - don't know what the '66 JG says.
