using jack stands - NCRS Discussion Boards
using jack stands
  • Ken Bushley
    using jack stands
    I need to get my 75 off the floor.Where is the proper place to put the stands?Thanks
  • Allen W.
    • September 30, 2000
    • 106
    Re: using jack stands
    How about the jacking points shown in your owners manual and in the shop manual. They are the frame rails behind the front wheels and just in front of the rear wheels.
    Allen
    • Tom S.
      • March 1, 2004
      • 1087
      That's where I put mine with no problem. I had mine up for several weeks this winter, and everything is fine. Tom Stanton #41491 P.S.
      Mine is a 69, but the same frame as your's.
      • Jean C.
        • June 30, 2003
        • 688
        Ken, if you plan to work under your car, it is not a good idea to have it up only on jack stands. See posts on this forum archives on this subject. If when your car is sitting on all four tires you can not slide under it with space to spare, you do not want to be under it when it is up on jack stands alone.
        Work safely,
        Charlie
        • mike cobine
          If you buy cheap stamped-steel jackstands, yes. If you buy the really good ones, you should be fine.
          However, in my old age (slower reactions at getting out from under) and having other inexperienced people around the garage who could do something nearly fatal, I like tossing a 255/60-15 tire on the rim under the low spot near where I am working. That should be enough to keep it off of me. I might get caught or pinned, but not crushed.
          If the tires are on it, the ramps under the tire give a bit of security.
          The real trick is ALWAYS give the car a real hard push and pull before getting under. While any of us would hate to drop our cars on a jackstand and poke a hole through the floor, we would hate even more to poke a hole through us.
          • KEN BUTCHER
            jack stands
            What they say is:
            DON'T LEAVE A VEHICLE UP ON A HYDROLIC JACK, WITHOUT JACK STANDS.
