What is the correct sealing compound and color to seal the heater to the firewall? Thanks, Jimmy
C1 Heater Seal to Fire Wall
Re: C1 Heater Seal to Fire Wall
I might be reading your question wrong, but my experience is that the large black rubber gasket that seals the air intake piece (snout) to the rest of the heater is also the seal to the firewall. That's the case at least from 56 through 62.That is a black/charcoal color.- Top
Mike -
I was trying to recall my '57 (which I did ten years ago); I think it used a formed gasket between the air inlet housing and the firewall that was made from a dum-dum type material, which one could make from strip-caulk material. Just looked in the Doc's catalog, and sure enough, he has that formed "putty" gasket. CRS after ten years- Top
