C3 F41 Front Stab Bar Bushing - NCRS Discussion Boards
  • Tom R.
    • June 30, 1993
    • 4081
    Is the GM# 3828826 bushing listed in the P&A for 63-67 same as that used for 68-69?
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    Re: C3 F41 Front Stab Bar Bushing
    Tom-----
    No, the 68-69 front stabilizer bushing for F-41 suspension was GM #3923674.
    • Tom R.
      • June 30, 1993
      • 4081
      Hmmmm...same one as for 70-75 big block.
      Tom Russo
      78 Pace Car L82 M21
      00 MY/TR/Conv
        Tom-----
        Yes, these bushings are not made to fit a single size sway bar. They fit a few different OD's since they COMPRESS AROUND the bar when the retainer bracket is drawn down with the mounting bolts. So, these bushings fit BOTH the 68-74 7/8" big block bar and the 15/16" (or, 1" depending what you get for a measurement) front bar used for 68-74 F-41 applications.
        • Mark #28455
          Didn't all BB use 15/16 1968 - 72? *NM*
            Re: Didn't all BB use 15/16 1968 - 72?
            Mark-----
            70-72 big block did use the 15/16" front stabilizer bar regardless of suspension option. However, 68-69 (as well as 65-67) big block used the 7/8" bar unless equipped with F-41. In that case, they used the 15/16".
            • Mark #28455
              1969 definitely used 15/16 for all BB *NM*
