67' rear end housing cover - NCRS Discussion Boards
  • Jerry A.
    • May 31, 1997
    • 122
    Differential rear cover # 3871375. Should this cover have a casting date near the drain plug hole for 1967 or were date codes cast in later???
    Again, much thanks!
    Jerry
  • Steve Wallach
    Re: 67' rear end housing cover
    I have seen some with dates and some without. I have heard for 67 they could may or may not have a date. It would be on the flange where the bolts bolt the cover to the housing near the drain plug.
    Steve
    • Philip C.
      • December 1, 1984
      • 1117
      Hi guys date codes are on pass side of the rear, true they may or may not have a date. Phil 8063
      • Jerry A.
        • May 31, 1997
        • 122
        Thanks Steve, Mine has a date.
        Jerry
        • Jerry A.
          • May 31, 1997
          • 122
          Thanks Phil, mine has a date!
          Jerry
