Muncie woes - NCRS Discussion Boards
Muncie woes
  • Rex T.
    • December 1, 1984
    • 455
    Muncie woes
    Took my 64 out for a cruise this afternoon, up the interstate a couple of miles to blow off some winter dust, and wound up with the trans stuck in 2nd gear (I think). At least that is what it seems. When I place the shifter in the normal 1st gear position, the car will not move, shift back to 2nd gear position and it still won't move. However, if I place the shifter just slightly forward of the normal 2nd gear position, it will go forward, but will not shift to another gear. Any thoughts on this one? At least I was able to limp it back home, nothing hurt but my pride (I hope). As always, thanks in advance for your help.
    Rex #8089
  • William C.
    • May 31, 1975
    • 6037
    Re: Muncie woes
    Start with the linkage, see if the nuts are tight on the shift arms, and the arms had the slots aligned with the shaft properly as a first step. True 64 shifter arms and the design of the shafts that come thru the side cover were not a robust as the '65 versions (and subsequent)
    Bill Clupper #618
    • Mike B.
      • November 1, 2004
      • 389
      Re: Muncie woes
      I agree with the linkage diagnosis. If the alternate levers such as 3-4 and reverse are not perfectly centered in their detent neutral positions, shifting of the active lever/gear can be virtually impossible. This is true for whatever gear you are trying to shift into. Simply get under the car and wiggle things around a bit. Maybe you will get lucky and find a $.50 linkage retaining clip broke and the rod fell off.
