68/69 door hinges, washer squirters?
Here is another odd thing about 68. The 68 door hinge is unique to 68 and early 69 only. Sort of interesting.
I have collected at least 2, possibly 3 types of washer squirters for 68. That is enough to drive a person crazy. What was up with that?
What about the location of the switches under the dash. Those were moving around in 68.
Trying to nail all this stuff down is next to impossible.
Chrome plated steel rivets or aluminum rivets on the spring tab of the distributor shield?? I have seen both on origial set-ups.
68 window cranks are unique to 68 only. Can be identified by looking at the back side at the part number and at the post insertion site.
Possibly 3 types of inside door handles in 68. 2 for sure, possibly 3. I say there are 3 types. What month were they started and stopped?
When did the upper door pull on the door panels show up on 68? Hmmm?
When did they stop using the plasitc center door for the rear compartment?
When did they start to paint the underside of the rear compartment doors black?
How late into production were spring hinges used on 68/69 for the rear compartments?
I have reason to believe that some rear pop-out windows in 68 were stamped easy-eye or soft-ray but were clear glass. They were correctly dated for the car but the glass was definitely clear. Hmmm? That's a weird one.
I have seen 3 types of door frames for 68. Some that had velcro attached at certain points that other didn't. Some that had a hole for electric window wiring and had manual windows?? The hole was plugged with a plastic plug. Some that had no hole in that same location and had manual windows.
Pop out window frame for 68. I have seen 3 different kinds. Main difference is in the corners and how they are jointed. Some pinned together, some screwed together and some had both pins and screws?? Hmmm?
Brake switch noise capacitor on 68. I have seen cars with them and with out them. My car did not have one. Hard to tell if the switch was replaced. I have collected many switches and I think only one had the capacitor on it. Need to look at some early cars and see if they were there or when they started to show up in production.
Speedometer and tach housings for 68. I have seen some that have each light hole on the back side labled with a color code. I have seen some that are not labled with a color code. I thing the early one's had no lable. It believe it was introduced later to make it easier to plug the wire harness into the right holes in the back of the dash.
Two types of vent levers used in 68. One was a riveted assembly and the other was spot welded. The chrome knobs on the levers changed but I can't remember the details on that. Had something to do with what was written on the knob I think.
Wasn't there a thing about the cross flags on the horn button not painted correctly? That is a good one.
Some cars had ashtray doors that would simply slide open all the time with vibration or excelloration. At some time in production they added a metal spring tab to the door to prevent the door from coming open on itself. It is mentioned in a tech bulletin. Find the cut off on that one.
What was the cut off on the front plastic bezel for the fiber optics? When did the pot-metal bezel show up. I have found 2 different sizes of pot-metal bezels both with the same part number on them. One is about 1/4 inch shorter than the other. Weird. That change may have taken place outside 68 production but I have not confirmed it.
Actuator canisters for the headlights?? What direction did the nipples face? Did they ever use two lefts or 2 right side canisters on a car? I think they did.
Wiper door actuator. Were the hoses rounded at 90 degrees as they attached to the vacuum nipple? I don't know? Some people think they were some say not.
Wiper door actuator boot on 68 had a straight flange on it. I am confident about that one and it didn't change untill sometime in 69. There is one thing I feel I know is true.
Just a bunch of thoughts. It is interesting but it also starts to put things into perspective. I don't know about picking this stuff that far apart. Rather just get the car on the road again and enjoy it.
I
I
