C2 Tail Light - NCRS Discussion Boards
C2 Tail Light
  • Clark D.
    • August 31, 2004
    • 50
    C2 Tail Light
    The passinger side turn signal will not blink on my 1966 coupe. I troubleshot it this weekend to a loose connection right behind the socket. I can snake my hand up and wiggle the wires and it will work. I cleaned the socket, no help. Now the dumb question: How do you, or can you remove the tail light assembly without removing the gas tank? Looking up there I see no alternatives. Any suggestions? Thanks
    Clark #42490
  • Ken Edmunds
    Re: C2 Tail Light
    Clark, I changed mine this weekend. It is easy to do if you remove the exhaust panel and then just reach up with a deep 7/16 socket on a quarter inch drive ratchet. No need to remove the gas tank.
    Ken
    • Dennis B.
      • May 31, 2004
      • 174
      Re: C2 Tail Light
      By removing the exhaust filler panel you can gain access to the tailights. Removing the muffler will give you further room. If you have sidepipes you are home free.
