Two questions regarding my 1963...
1) On the the fan clutch drive... How can I tell if it is operating properly? When I run the car, it spins, but keeps spinning when the engine is shut off.. never seeming to be directly driven.
2) Battery Cables - I bought a reproduction set from our friends in Michigan; a long brown one and a shorter black one. Which is which; positive and negative? I had them installed but had to switch them to (Brown = Negative), (Black = Positive) once I also installed a reproduction battery... they would not reach otherwise... Is this correct?
Thanks, Joel
Thanks, Joel
