I have a 3743833 P CASE for a 61, 4:11 posi. Where can I get info on the pre-load (inch pounds of torque) that the pinion should be set at. Also if the pinion nut has been torqued to tight previously will the crush sleeve need replaced. I'm not real confortable on how to properly this up and would appreciate your thoughts.
I referred to the st12 and my setup isn't the same as described in the manual. Thanks
Leon
Leon
