I've found that a series of short cranks, separated by 20 second waits, works best.
First, crank for no longer than 5 seconds. Then wait 20 seconds for some of the gas to evaporate. The engine will probably start on your next 5 second crank.
I believe the wait between cranks is necessary because the FI nozzles squirt liquid gas directly on the back sides of the intake valves. A gasoline vapor is much easier to ignite than a liquid.
If your engine has been sitting unused for more than a month, your fuel bowl will probably be empty. That will cause a delay in starting if your unit has a Cranking Signal Valve. All '58 - early '64 units with a CSV require about an inch of gas in the bowl to start. A stock '59 7300 series unit doesn't have a CSV.
