I need help again. I have three groundwire questions for my '56 :
1. the ground strap that is just below the ballast resistor, one end is connected to the bolt of the cowl vent mechanism that comes through the firewall, where does the other end connect to? I think it goes to the accellerator bracket at the firewall but not sure. The AIM shows it attaching to the accellerator linkage but I know that is wrong.
2. the black ground wire that leads from the heater motor next to the brown wire, about five inches long, I think connects to the outer squirrel cage?
3. I have a black wire that one end was attached to the back of the speaker frame behind the dash, where does the other end go? It is about twelve inches long. I don't remember anything about this one.
Thanks!
Thanks!
