replacing inner seat belt reinforcement - NCRS Discussion Boards
  • adam moran
    Have to replace both inner seat belt reinforcements and i was wondering what rivet and washer is used to replace the originals i have check the AIM and it does not give a good reference to what is used and i want to make sure that i put the right parts back into the car. any help would be appreciated and thank you
    ADAM
  • Terry F.
    • September 30, 1992
    • 2061
    What year car? *NM*
    • adam moran
      Re: replacing inner seat belt reinforcement
      62
      • Dennis A.
        • April 30, 1999
        • 1010
        Adam...
        Both Paragon and CC have the soft aluminum rivets 50/100 per bag. Universal Head 3/16 dia.X 9/16 long. Countersink heads are also available...
        • adam moran
          tried both they have nothing with the washer that go with the rivets were they factory installed or added by someone else.Thank you
          Adam
          • Gene B.
            • May 31, 1990
            • 144
            Adam,
            Dennis is correct. The aluminum rivets are the correct way to attached them. If there is a washer on the back side it is Bubba's repair. The rivets were peened over with a tool that made the rivets rounded, or mushroomed over on the underside of the car and the top part of the rivets was inside the car. At least that is the way they were on my 58. I highly doubt whether the procedure was changed through 1962. You might ask Reverand Mike Ernst. He would know for sure.
            It will require you and a budddy to do it correctly. I used an air chisel, with the chisel bit cut off and then rounded/hollowed out the bit with a grinder/dremmel tool. This made for a nice mushroomed over head on the underside of the car. You will need a buddy with a heavy hammer pressing hard against the top side of the rivet to prevent the rivet from popping out while you use the air tool. You can hammer it too, but the air tool make it a lot easier and quicker.
            Gene
            • Dennis A.
              • April 30, 1999
              • 1010
              Air Hammer is the way to go... set at 15 - 35 p.s.i. hole the trigger until the end of the concave tool has bottomed out on the surface of the metal part. Several aircraft tool suppliers offer the setting tool on the web and C.C. has them
              (which I never tried)
