1988 Aux Cooling Fan Wiring - NCRS Discussion Boards
  • Bill B.
    • September 30, 2002
    • 351
    I recently acquired an 88 4+3 covertible with aux cooling fan. The previous owner "reworked" the front harness to install a C5 conversion kit (changed lots of lighting sockets, cut wires, ect.). I immediately put the car back together with original bumpers and "reworked the reworked" front harness. My Aux relay is located on left radiator shroud and has four wires which are all about 12 inch long cut wires. Primary Fan setup is fine (hot, to fan motor, Pin B7-C100, and Pin F6-C100. Following is what I need to know on the Aux Relay:
    Red/Black - CAN FIX (to Aux Fan Motor)
    Red - CAN FIX (fused 12v battery)
    Green/White - ? (is this an ignition wire from Pin ?-C100 or does it splice to same GRN/Wht Pin B7 on Primary Fan relay or go somewhere else)?
    Blue - ? (I have no idea)
    In Summary, where in the world does Aux Grn/Wht and Blue go!
