torque for cylinder heads - NCRS Discussion Boards
  • BIGARDA
  • BIGARDA
    Re: torque for cylinder heads
    IS A L48
      BIGARDA-----
      The torque for the cylinder heads is 65 lb/ft for all bolts. The valve adjustment procedure will be found in your 1979 Corvette Shop Manual. If you don't have one, you need to get one. They're available from the NCRS bookstore for a modest cost.
      • BIGARDA
        I HAVE IT. THANKS
        • Kent K.
          • December 1, 1982
          • 1139
          All caps is shouting
          Please turn your caps lock off. It makes for much easier reading. Posting with all caps is like shouting in internet protocol.
          Thanks, Kent #6210
          Kent
          NCM Founder - Member #718
