Hi Folks,
Was having some ignition probelms with my 1960 dual point distributor. I noticed the rotor from sSandard was very loose, DR309. Delco is not making them anymore. I got some Blue Streak points and condenser that seem to work, dr2236xp
and put in an old rotor I had. Fixed the problem. But it raises the question, what manufacturers are producing parts that are till up to spec? ie cap, conden, points, rotor?
Is it time to put in a Pertronics? What success are folks having with that?
If any is using/recommends the Pertronix, there are two models of that, which one is for the dual point 2X4 - #891 distributor?
Thoughts?
Thoughts?
