6 cyl Distributor Question - NCRS Discussion Boards
  • Robert S.
    • July 31, 2004
    • 377
    I need some old-timers to dust-off the cobwebs and see if anyone can recall the answer to this question:
    ST-12 Sec. 12-32 electrical Systems has a diagram of the 6 cylinder distributor. Items 5, 6 and 7 are the Grease Cup, Plug Spring, and Bakelite Plug, respectively. I know the Grease Cup is to hold the chassis lubricant per the manual.
    The Question: What is the purpose/function (mine is missing) of the Bakelite Plug and Spring? The spring goes between the Bakelite Plug and the Grease Cup.
    1. To limit or restrict the amount of chassis lubricant that can enter the distributor housing at one time? (Normal maintenance calls for the Grease Cup to be turned down one turn every 1,000 miles.)
    2. Restrict pressurized (54-55) engine oil from entering the Grease Cap?
    3. None of the above...you don't need it anyway! Have another drink
    Bob
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 6 cyl Distributor Question
    i like # 1 but go ahead and have another drink.any old 216 or early 235 chevy pass car 6 banger ought to provide the missing parts.if you can't find at junk yard, let me know. i probably have the pieces. mike
    • Robert S.
      • July 31, 2004
      • 377
      Thanks, Mike! I'll check around locally. Cheers, Bob
      Bob
