After reading so many good reviews from Members who swear by reproduction radial tires for the street, I bought a set of Coker Classic redline radials and powder coated rally wheels for the steet, and will keep the bolt on aluminum wheels and OEM's for show only. The car handles a LOT better, but I still experience a little wandering of the rear end, but nowhere as bad as with the OEM's. I was thinking that maybe an adjustment of the camber and toe in might be in order.
Right now I have the rear wheels aligned to factory specs, but the radials seem to have more tread width, and I'm not sure if the factory settings would be correct. For those of you that have switched to radials, did you find that the ride was greatly improved using the factory specs or was an adjustment required? Any thoughts? Thanks.
