Hello Everyone,
I need some help with an issue regarding the rear brake line clips that hold the steel lines coming from the calipers to the rubber line going to the brass block. I've looked at my AIM several times and cannot determine if the clip goes on the side with the steel line or under the tab on the frame towards the rubber line side. It seems that the line is most secure with the clip on the steel line side above the frame tab (viewing frame from above). When I put the clip on side with the rubber hose, the line seems to shift and is not very secure. Does anyone know the correct way for this assembly??
Thank you!!
John Osterholm
Thank you!!
John Osterholm
