How to install Dipstick tube on a c2
  • jim #42767
    #1
    How do I get this new dipstick tube back into the block? Any tricks?
    I have searched the archives with no success.
    327/350
  • Kent D.
    • February 1, 1992
    • 100
    Re: How to install Dipstick tube on a c2
    It should slide right in. Is all of the old tube out of the block?
    • Steve D.
      • February 1, 2002
      • 377
      Jim
      Try putting it in the freezer for a while, to let it contract and give a bit of clearance.
      Steve
      • John O.
        • June 1, 1998
        • 480
        Hi Jim
        I have a 62 vette and what I did for mine was put some oil on a q-tip and rub it in around the hole and around the tube end.Set the tube in the hole and with a blunt end screw driver and hammer, tap the little flange to seat the dip stick tube. It worked for me.
        Good luck..........John
        • Clem Z.
          • January 1, 2006
          • 9427
          find a box end wrench that fits over the tube
          and rests on the dip stick tube flange and then tap it in with a hammer on the wrench
          • Barbara S.
            Infrequent User
            • May 1, 1981
            • 0
            Re: find a box end wrench that fits over the tube
            Stupid question, but are you putting the correct side down? I had real trouble putting mine in--it just wouldn't go in. Then I turned it upside down (the correct orientation, and with a small smack with a rubber mallet, it went right in.
            Good luck.
            Tony
            • jim #42767
              I used a socket and long extension over the tube and hammered it down. Worked like a charm.
