For you people that are restoring your Corvette C1's, I've had many people ask about the "trans cross mount" support having (shims) and why or how do you determine the angle on a stick or Automatics to get the drive shaft aligned correct so that the U-joints don't bind or get a vibration.Using a bubble gage reading in degrees placed on a flat area in line with the rear pinion read the angle.
The idea is to make them COMPLEMENTARY. So, if the rear is, say, 3 degrees
DOWN bubble, you want to lift the trans to be 3 degrees UP. This way, the
Front and rear U-joint form a parallelogram and will spin together happily
Without strain.
If you could visualize an imaginary line coming straight out of the trans would go down a bit, and one coming out of the pinion up a bit, but the two lines would be PARALLEL to each other, never meeting. Make sense?
When ever replacing rear springs, motor mounts or trans. mount this should be checked .IF you have a vibration and cant locate it I would start there. Hope this may help others out there.
Without strain.
