After diddling around with lobe design - basically trying to cut down the L-72/LT-1 inlet lobe to achieve the duration and dynamics I was looking for (It ain't as easy as I thought going in!) I bagged it and started "mixing and matching" OE SB lobes.
As OEM machined, "big port" SB heads (461, 462, 186, 492, etc.) have an E/I flow ratio of about 0.65, which needs a cam with longer exhaust duration in the form of a relatively early opening exhaust valve, and many OE cams feature this design architecture.
But when you pocket port the heads, the E/I ratio ends up at about 0.85 because pocket porting and the relatively short exhaust port combine to yield a much better improvement in flow effeciency on the exhaust side than on the inlet side, and this calls for a totally different valve timing scheme.
My goal is to increase torque bandwidth - almost as much bottom end grunt as the 300 HP engine with nearly the same top end power as a SHP engine. I used Engine Analyzer for most of the work along with lab and RW dyno tests from some engines that I have system engineered and have test data.
Right now the best combination is the L-46/82 inlet lobe, retarded six degrees combined with the 300 HP cam exhaust lobe advanced 4 degrees. Since the detail design data for these lobes is availalbe, it wouldn't be hard to have a custom ground cam manufactured assuming a blank is available that will support the "unconventional" points of max lift (POML) indexing for the lobes. (I use the term "POML" because the lobes are asymmetrical and the "centerlines" are not coincident with the POMLs.)
Basic specs are as follows (inlet/exhaust) and, of couse, it is a hydraulic lifter design:
Duration at .050" lifter rise, 224/202
POML: 120 ATDC/120 BTDC
LSA: 120
Gross lobe lift: .3067"/.2733"
This design looks decidedly "unconventional" compared to OE and especially typical aftermarket designs, but if you compare to modern LS-X cams, it's in good company.
Using the new LS7, which is the most extreme example, keep in mind that the designers intentionally crowded the exhaust port/valve to make as big an inlet port/valve as possible and ended up with a E/I ratio of about 0.65 (even with full CNC machining of both ports), which was a good decision because the "restrictive" exhaust port can be compensated with an early opening exhaust valve, and this is reflected in the timing and POML data.
The durations at .050" lifter rise are 211/230, inlet/exhaust, but the real revelation is that the POMLs are 124/117, which yields a LSA of 120.5, and almost no overlap. The inlet event is "extremely retarded" and the exhaust event is "well advanced".
The reason is that overlap and backpressue, even the low backpressure from a good low restriction exhaust system are mortal enemies! It's like mixing ammonia and bleach. The proof that this timing scheme is viable is reflected by the LS7's prodigious 80 percent torque bandwidth which extends from less than 2000 to about 7000.
This "new" SB cam I've cooked up represents the same philosophy albeit with the durations swapped to reflect the relative E/I ratio of vintage SB POCKET PORTED (not as OE machined) heads and the OE CNC ported LS7 heads.
Keep in mind that this valve timing is optimized for a SB with pocket ported head E/I flow ratio and WILL NOT perform well on a vintage SB with un-reworked heads. The "small" 1.94/1.5" valves work just fine with this cam on a 327 with the 2.02/1.6" valves only providing a marginal improvement. This valve timing will also produce similar results on longer stroke engines - 350s and 383s, again with pocket ported heads, but the 383, in particular will benefit from the larger valves.
This cam could yield a OE appearing 300 HP engine that makes nearly as much top end power as an SHP engine, and with proper "zero lashing" it should rev useably and cleanly to 6500. There will be a loss of low end torque, but only about half of what is lost with an OE SHP cam, and the idle quality will be just like a 300 HP engine - 500@18" and butter smooth.
If you select cams based on "how they sound at idle" go elsewhere and forget you ever read this, but if you have a 300 HP engine and want a "sleeper" with absolutely original appearance, this may be the hot setup.
LSA: 120
