Gentlemen,
I just received my water pump back from the rebuilder. Unfortunately I realized after mounting that the hub was not pressed back far enough on the shaft and the pulleys now do not line up. I do have the 1/8" harmonic balancer spacer in place but the water pump pulley is too far forward by about 3/16". This is before I install the reinforcement spacer between the hub and pulley which will further widen the gap. To be fair this was a replacement pump found at a swap meet that had never been on the engine. I did not take the time to test fit it beforehand and just assumed...
I will take a series of empirical measurements so that I can instruct the rebuilder the press the hub back in further. But can someone provide a sanity check on the distance say from the front of the hub to the mounting flange faces or some other fixed point? The pump is a "609" for a 1961.
Also so that I can be extra sure, can someone also provide the height of the water pump pulley? I thought mine to be correct but it now realize there are no numbers stamped on it. I want to check that the offset is right.
Thanks in advance.
Mike
Thanks in advance.
Mike
