Could you get traction bars from the factory or GM dealer installed in 1961 or other years on Corvettes?
Factory Traction Bars 1961
Tags: None
- Top
Re: Factory Traction Bars 1961
These look like normal traction bars from the bottom of the spring to the frame.- Top
Here is a pair of very old Lakewood traction bars that were on my '57 when I bought it. PT
Attached Files- Top
If they mount on the bottom of the spring and are fixed to the frame at the front spring eye, they're probably Traction Master brand bars. That's what a lot of guys used after they ripped the stock ones loose like Clem did.
The ones Patrick posted a picture of were "slapper bars" and they became common, at least in my area about 1965 or so. I think Lakewood made one of the first designs followed by everybody and their brother.- Top
Re: Wait- you mean these aren't 'original'?
Rob, My car ('62) came with the same set up when I bought it back in the 80's. They work like a charm, very nice launch. I noticed you have a slightly bent U-bolt, mine did too, the U-bolts have to be quite long to clear the sway bar mount using the spacers. Once I started on a frame off I inquired to Traction Master in CA about refurbing mine with new front mounts, poly bushings and hardware. They no longer had the drawings so I sent them mine as a reference to work from. You can now buy a set of new Traction Master traction bars for your vintage solid axle. The only diff is the saddle mounts underneath the axle are now welded instead of cast. I decided not to use them for the present since I've never driven the car without them. I'd like to see how it rides and handles without the T-bars. Using them on a '61-62 with factory strut rods, you have a multi link set up on the rear axle and I think quite a bit stiffer ride. If anyone is interested in them contact Chuck at Traction Master.- Top
