A little more specific to my question,I am refering to the black paint on the frame and other parts. Thanks
under carriage detailing
Re: under carriage detailing
Ron...
Best tool in my garage for touch-ups is an Airbush, aluminum foil is easy to use for masking around the area you are going to touch-up. As with all touch-ups, getting the paint to match takes some luck, spraying some chips with a hole in them and overlaying the sprayed chip on to your frame will give you an idea if you are close to a match.
Good Luck- Top
