I am in the process of disassembling an ORIGINAL 327/300hp motor due to excessive ring blow-by (blue smoke, high compression leaddown test +70%, and oil in the air cleaner). Motor has 90k miles on it and, I believe, has never been rebuilt.
My plan is to recondition a steet 300hp OE motor...guides (cast or bronze?), 3 angle valve job, NO HARDENED SEATS, new cam/lifters/springs/seals, bore/hone +.020 with SP HP660CP pistons, second design OE rods on orig. crank, and OE cam. Target static compression ratio of 9.75. So far, I have removed heads, and measured piston to deck clearances (.023 right, and .029 left). I have yet to measure bore wair, but there appears to be only a slight cylinder ridge (.001-.002).
Please respond with any suggestions! I am also looking for recommendations for reputable Chicago area machine shop. I hope to keep machining to a minimum (clean, bore?, valve job & guides, cam bearings). I will do all the assembly.
JimV
JimV
