I have been following the discussion in another thread about a 327/300 rebuild, and I have a question about the induction hardened valve seats that GM apparently started using in 1973 or so.
My question is about the external appearance of the GM heads that have induction hardened seats. Back in 1976 I built a 327/350 using new GM head castings. I recall that a knowledgeable friend recommended a specific GM part number because "it has induction hardened seats." As I recall, these heads had the familiar double-hump casting feature on the ends.
Are the newer head castings with the induction hardened seats externally identical to the ones originally used for a 1967 327/300? If so, what model years or part numbers would qualify?
My 1967 327/300 presently has its original heads, based on the casting numbers and casting dates that are only visible with the valve covers off. However, when the time comes to rebuild the heads (not soon, I hope), it would be tempting to set the originals aside and rebuild another set that has induction hardened seats. I would only consider this if the external appearance of the newer heads was indistinguishable for judging purposes.
I realize that the need for hardened valve seats is highly debatable, and I have already concluded that the risks of installing hardened valve seats outweigh the possible benefits. However, I might consider using newer castings with induction hardened seats as a precaution if there is no downside to doing so.
