61 Corvette ignition switch wiring HELP needed - NCRS Discussion Boards
  • Dick G.
    • May 31, 1988
    • 681
    A friend of mine (1500 miles away) called me about his ignition switch he changed out today. He's had problems starting his fuelly lately and has found the Ignition switch was at fault. The car now starts. His question to me is which of the 2 pink wires on the back of the Ign. switch are for the ACC.. The 14 or 18 gauge. According to a wiring diagram I have, the 14 pink is the ACC.. Am I correct. The 18 gauge goes from the Ig. switch to the fuse panel to what I believe is the (FLASHER??), not sure. Why would the flasher come off the Ign. switch? Am I right? 14 gauge ACC. Thanks Dick Gutman
  • Donald L.
    • September 30, 1998
    • 461
    Re: 61 Corvette ignition switch wiring HELP needed
    Dick,
    You are correct. 14 gauge to ACC and 18 gauge to ignition post of the switch.
    Donald #31176
