C2 radio bezels - NCRS Discussion Boards
C2 radio bezels
  • Joseph K.
    • March 1, 1980
    • 168
    C2 radio bezels
    Am trying to replace the bezels that reflect light from the radios lamps to illuminate radio dial. While the volume and station controls are readily removeable the one locate above them have a threaded nut to remove and one appears to screw off. Can anyone help guide me through their replacement? Thanks for any help.............Joe
    Re: C2 radio bezels
    Joe -
    The radio dial is illuminated with its own bulb inside the radio; the bezels around the control knob shafts are illuminated from the "torpedo" lamp that clips to the bottom of the clock receptacle. In any event, there's a nut on each of the two control shafts that retains the top of the radio to the dash panel (and retains the plastic bezels in place).
    • Joseph K.
      • March 1, 1980
      • 168
      Re: C2 radio bezels
      Thanks for the info but how is the knob on the upper right shaftremoved does it srew off. Thanks for your input it really helped.....Joe
      • David D.
        • 330
        Re: C2 radio bezels
        Joe, Loosen the set screw, to remove. Dave
