I have been following the posts out here on manifold vacuum and the vacuum advance can on the distributer and have a couple of questions.
On my 1963, 327/340, I am running a Competition Cams stick which is slightly hotter than the stock solid lifter cam. When I run the car, the most I get by way of vacuum is 13 inches of mercury when measured out of the vacuum advance line at the base of the carb. I have been chasing this down as a potential intake manifold leak (this is the car which produces oil smoke out of the right cylinder bank when hot) thinking I should be seeing 18-20 inches. The distributor has a B1 vacuum can.
Two questions; what should I be seeing by way of vacuum?? and is the B1 vacuum can correct for this application?
Thx!
Joel
Thx!
Joel
