C2 Big Block Fuel Pump Installation - NCRS Discussion Boards
  • Mark P.
    • July 31, 2003
    • 407
    I've got a 66 L36 and I looked through the archives and found out everything I wanted (or didn't want) to know about small block fuel pump installations, but nothing specific on big blocks. Any special procedures with regard to pump rod retention with grease and longer bolts, etc for a big block?
    Thanks in advance for any advice.
    Mark
  • Kent D.
    • February 1, 1992
    • 100
    Re: C2 Big Block Fuel Pump Installation
    I use grease.
    • Jim T.
      • March 1, 1993
      • 5351
      You probably read this in the archives. Bump the engine over with a finger holding the fuel pump rod so you can install the pump with the fuel pump rod retracted in the block as far as you relocate it.
      • Mark P.
        • July 31, 2003
        • 407
        Thanks...I think that's what I was looking for. I just needed a confirmation that the procedure is similar.
        Mark
