63_Steering column bearing upper - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    In the picture below, the bearing assembly on the right was removed from the car; the one on the left is a 63 replacement from LIC. The one on the right looks more like the drawing in the AIM. Which one (if either) is early 63? The car had an October 62 build date.
    Steve
  • Timothy B.
    • April 30, 1983
    • 5177
    Re: 63_Steering column bearing upper
    Steve,
    The bearing on the right is correct for you 63 except the horn ground wire is missing.
    • Steve D.
      • February 1, 2002
      • 990
      Timothy
      Do you recognize the other one?
      Steve
      • Roy B.
        • February 1, 1975
        • 7044
        53 to 62
