C2 green washer fluid found. - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    Collin MacDonald and others. Recently you were looking for green w/s washer fluid for your '63. CarQuest has it in stock by the gallon. Part No. CQWWS. I believe this store is nation wide.
  • Michael H.
    • January 29, 2008
    • 7477
    Re: C2 green washer fluid found.
    John,
    Yup, saw it at the auto parts. It's a slightly different color green but close enough I suppose. Wonder if all the cars at the next event will have green juice in the washer bottle? Bloomington should be interesting.
    • John D.
      • December 1, 1979
      • 5507
      Michael, I really think you should inform the head honcho in GA that he should be looking out for the green fluid. Major deduct for the blue. hee. On a serious note no one said anything when I mentioned the color of the '63 washer bottle cap. Do you agree that it's a redish brown and not black? At the Auburn regional last week I saw one on a '63 and after the show we went to look at two unrestored '63's and they had the brownish cap. Thanks, John
      • Michael H.
        • January 29, 2008
        • 7477
        John,
        Yea, I'll be sure to pass the green juice info along to headquarters. That info is saved in a special place.
        I also have seen some of the weird colored w/s/w jar caps but the majority have been black. I never did understand the odd color on just a handful of 63's. I wouldn't deduct points either way.
          Michael -
          The '67 JG sez either green or blue is acceptable - don't know about the others.
          • Collin MacDonald
            Thanks for the info, I will check it out. Since this is the first time I am being judged I want the 63 to be ready for anything. I just finished mixing a batch using water, green food coloring (3 drops) and green rubbing alcahol to give it that old washer fluid smell...it came out perfect... But I much rather buy the correct stuff, I will check it out tomorrow. Thanks
