C2 - Another '63/'64 Fun Fact - NCRS Discussion Boards
  • Gordon Peterson #4961
    How can you tell a 63/64 coupe door panel from a 63/64 roadster door panel? Most of us know that the location of the vent window crank is different. But do you think I can remember which is which when I see a panel? HAH!
    Well, here is a coupe panel. Note the perforated line where the roadster vent crank hole would be. Now I'll be able to quickly check when I see one.
    Pete
    P.S. - Has anyone ever figured out what this other little hole is that is covered on the outside by vinyl? Me neither. It appears to be in all the 63 panels I've seen though.
  • Donald M.
    • December 1, 1984
    • 498
    Re: C2 - Another '63/'64 Fun Fact
    Gordon, Maybe that small hole is for the remote controlled outside rear view mirror option.
    Don
      The coupe panels are also "notched" at the top front corner to fit around the upper portion of the door inner panel forward of the vent window.
