I replaced the NAPA clutch (earlier posting) with a LUK clutch today. The good news is that I now have adjustment for pedal travel. The bad news is that when I was hooking up the linkage to first and second gear shifter shaft and detent plate the threaded shaft snapped. It looked to be a very weak casting and I was only using light force with a box wrench. This is an original 1963 Muncie transmission (July car); is the shifter shaft the same with all year Muncies or am I into one of these one year only deals again. Can this part be installed with the transmission in the car or do I have to remove the transmission again?
Thanks for any help!
Ray
Ray
