C1 heater hose to core copper 90 tube - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    I am installing the heater in my '60. The heater hose from the water pump connects to a smaller piece of hose that goes into the heater core via a 90-degree copper tube. The copper tube looks like it is all 1/2-inch OD from one end to nearly the other. At one end, the 1/2" has been expanded to maybe 5/8. This is so the large heater hose can be adapted down to the smaller piece of heater hose that goes into the core.
    My question is do I have the correct piece? If so, how in the world does the 1/2" tube with no ridge, rim, or anything keep from pulling out of the hose? I put the hose on it with an RC 15 clamp and the clam was very tight. Yet I can still pull the tube right out of the hose. I would be afraid to use it like this.
    Bob
  • John O.
    • May 31, 1998
    • 480
    Re: C1 heater hose to core copper 90 tube
    Hi Bob
    I had the same problem with the 90 degree elbow. I even ordered a new one thinking mine was not correct. It's the same. Since I have spent alot of money restoring my 62, I did not want to chance a leak, so I just used a regular screw type clamp for that elbow.I believe that the original hose may have been a smaller diameter.I think what I will try is, on the extra elbow I have, is try to expand the smaller end so it fits tighter.Hopefully it will work.
    Good luck............John
    • John M.
      • January 1, 1999
      • 1553
      Bob,
      The elbow is as you describe. Many vendors sell an elbow that is smooth where the hose goes on, and this fitting is a recipe for leaks. The correct elbow will have a rolled bead on each end like the neck on a radiator to assure good sealing. I know that Paragon was selling the correct elbow last time I bought one. The smooth end one that a lot of vendors sell, is nothing but a common copper Street-L that you can pick up at any plumbing supply for less than a buck. If you want to use the original Corbin calmps, you can almost assure a leak with the smooth end fitting.
      Regards, John McGraw
      • Kent D.
        • February 1, 1992
        • 100
        On my '60 I glue all the hoses on with gasket sealer and use the corbin clamps. No leaks.
        • Bob Simard
          What I did to solve the problem was to use plumbing solder and flux to place a bead of solder around each end of the copper street ell. This provides the equivalent of a rolled edge and keeps the clamp on. I used worm style clamps since my car is a driver and will not be judged. So far no leaks.
            The correct elbow is 5/8" on one end and 3/4" on the other (to match the correct hose diameters), and has a rolled retention bead at both ends; Paragon has them.
