Hi all.
I'm experiencing a blown fuse problem. On my 62 corvette, I did a complete frame off restoration. I installed a new wiring harness through out the car.I'm near completion of the resto job. A week ago I noticed the tail lights, turn signals were not working. I checked the most obvious, which is the fuse and noticed it was blown.I replaced it and the lights worked. Now I had to disconnect the battery cables to put the battery hold down on. After reconnecting the cables, I noticed the tail lights were not working again...... Blown fuse again......What could be causing this ? All I did was disconnect and reconnect. Any thoughts?
Thanks.....John
Thanks.....John
