I bought a 73 and the rear at the wheelwell heigth was more between the tire and the wheel than I noramally see or want. Before any work was done the LH wheelwell was 29" and the RH was 30 1/4" to the top of the wheelwell. The bolts were removed and the LH was 5 3/4" long and the RH was 5" long. The short bolt was the high side a buba fix maybe. I installed new cushions and some 6 1/4" bolts which I think are stock on a 73. My end result was 29 1/4" on the left or + 1/4". On the RH it was 30" - 1/4". I improved from 1 1/4" difference side to side to 3/4". If just the bolt is changed and the cushions stay the same will that side get lower with a longer bolt?
Lyle
Lyle
