1955 gas tank restoration - NCRS Discussion Boards
  • Michael L.
    • July 31, 2005
    • 562
    Has anyone had good experiences with POR 15 gast tank renew kits? My tank is solid, just has varnish inside and a bit of surface rust outside. I'd like to do this myself, anybody worked with this before?
    Mike
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 1955 gas tank restoration
    To cleaned mine I put a gallon of Acetone in then shacking the tank around ,removed all of it looking like new.
    • Christopher R.
      • March 31, 1975
      • 1599
      1. Now you've got a gallon of dirty acetone. How are you going to dispose of that?
      2. Did you treat the interior of the tank? If not, how will you keep it from rusting?
      • Dave Suesz
        Too easy...
        1. Put it in an old bucket outside for an hour. It'll be gone.
        2. No need, the inside of the tank is galvanized, he only needed to remove built-up crud, which is now in the bottom of the bucket.
