1973 AIR Pump to Solenoid - NCRS Discussion Boards
  • Randy Loiselle
    I am in the process of reinstalling my AIR pump for a Judging meet on Saturday. Unfortunatly I can't remember the proper routing of the AIR pump to the Solenoid. I have the AIM and Service manual and neither one shows a detail picture of the routing. The Solenoid has 3 places for vacuum hoses, the AIR pump has 1. If I had a picture of the Solenoid and the carburator I could figure it out. If someone could help it would be much appreciated.
    Randy
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 1973 AIR Pump to Solenoid
    Randy
    You do not use the metal tube at the rear on a 73 with a 4 speed. The side port to the dist. The front port to a tee one end to the diverter valve the other to the carb at the RH front. Try Dr Rebuilds web site for pictures of other 73's routing.
    Lyle
    Lyle
    • Randy Loiselle
      I should make it more clear. I am looking for Vacuum hose routing. It is an automatic L48, which is different than an LS4.
      Sorry for the confusion.
        • 11608
        Same answer.
        See Dr. Rebuild's pictures on his site for diagrams of the vacuum hose routing.
        Patrick
        • Randy Loiselle
          I found it, it was exactly what I was looking for. My routing was so far off no wonder I could't figure it out.
          Thanks, to both of you.
          Randy
            Randy------
            .....and thanks to Dr. Rebuild!
