Correct Die-cut Door Handle Gaskets C2 - NCRS Discussion Boards
  • Peter M.
    • February 1, 1984
    • 361
    Pg 49 of the 1966 JG dicusses door handle gaskets "edges are visable". Is there a basic tolorence regarding how closley the gasket edge follows the contour of the handle ? ie did any extend out past the handle edge in normal production and is that judged ? Does any particular vendor offer the "truest" conformance to original ?
    Re: Correct Die-cut Door Handle Gaskets C2
    Originals fit pretty close to the handle contour, but you CAN see them when they're installed. What's in the Dr. Rebuild catalog is a good match...
