I know reams of information have been written about this subject, but I have what I consider a unique situation with my '62' gauge.
It stays on empty even when the tank is more than "empty". So, I remove the gas tank cover and pull the sending unit, turn the key on and run it through it's range and the gas gauge reads perfectly. Put the cover back on and the gauge is working wonderfully. Start the car, and the gauge goes back to empty and will not move off of it, until I repeat the procedure describe above. Start the engine, yep, same story. Have tried running an independent ground, etc. and to no avail. Has anyone ever had this type of situation before, and if so, can you suggest a remedy?
Thanks for any help you can give.
LonniezC
LonniezC
