I sent my trailing arms to Bairs for a complete rebuild, and they came back looking great. However, I was surprised that the spindles were rather hard to turn. I'd like to know whether this stiffness is normal.
If the spindle has been sitting for a while it requires moderate force to start turning it by hand (maybe a few foot-pounds). Once it starts turning the rotational resistance is reduced, but if it sits for a while it goes back to the high-resistance mode.
I decided to check the end play using a method similar to what is described in the service manual. I mounted a dial gage to the trailing arm using a magnetic base, with the gage indexed on the center flange of the spindle. Then I used a large screwdriver as a lever to put pressure on the spindle, first trying to force it outward axially, then inward axially (using alternate pry points on the inside and outside of the spindle bearing assembly).
The result was that there was no measurable end play at all, not even one mil. This concerns me because the factory spec is 1 to 7 mils, and I have read on this tech board that the bearings will fail prematurely if they are assembled with a preload.
I called Bairs to ask about what I had measured. They told me that the stiffness I feel in turning the spindle is due to the seals, not the bearings. They said they set up the bearings dry with 2 mils end play, then pack them with grease and assemble the spindles. It sounds like they do not perform a final check of the end play of the finished assembly. Their basic view was that my measurement procedure is probably not accurate and I shouldn't worry.
It just seems to me that there should be some measurable end play in the assembled spindle. The absence of measurable end play, combined with the relative stiffness in turning the spindle, has me concerned.
Does anyone on this board have experience or advice to offer? Am I worrying unnecessarily? I know that Bairs has a good reputation for this type of work, but I'm uneasy with what I am seeing.
