Original ign shielding grounding clip - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    The original grounding clip on my '67 had markings(can't remember exactly what they were) on it, not found on the repros. Does anyone know if a '66 gounding clip(small block) has a similar marking identifying it as original?
  • D S.
    • March 1, 2005
    • 1551
    Re: Original ign shielding grounding clip
    The one I have has AWT stamped into the metal.
    • Rob A.
      • December 1, 1991
      • 2126
      Scott,
      Thanks...no that you mention it, I remember that being on mine as well.
      • D S.
        • March 1, 2005
        • 1551
        I got mine with an ignition shielding off of eBay. I think it is an early '68, a carry over from the late C-2 era. At the time I was concerned that I got a part I didn't recognize as I have an early '70 which had the grounding tab riveted to the box, not clipped on.
        • Bernard M.
          • August 31, 1994
          • 341
          Rob, I bought one from GM in the mid '70s for my '63 but never put it on. I sold the car in '79 so it was purchased in the six years prior to that. It has lived in my box-o-parts ever since. I just dug it out to see the light of day. It has a small "C" stamped on it; that's all.
          • Rob A.
            • December 1, 1991
            • 2126
            Thanks for the reply. Sounds like all the originals had some marking, as opposed to none on the repros.
            • Alan Drake
              Understand the rear grounding clips were marked "CARB" or "FI".
              See the Restorer Article by John Amgwert "63-67 Sting Ray Small Block Ignition"
              Not sure of date.
              • Rob A.
                • December 1, 1991
                • 2126
                Alan,
                Thanks, I have an original clip for the rear. I want to make sure I find an original clip for the front.
