1960 WCFB Problems - NCRS Discussion Boards
1960 WCFB Problems
  • motorman
    Re: 1960 WCFB Problems
    the easy way to get any dirt out of the needle and seat with out removing the carb is to disconnect the fuel line from the carb, plug the fuel line so no gas can come out. start the car and run the carb out of gas, this will let the float drop clear to the bottom of the float bowl and allow any dirt that is in the needle and seat to be washed out after you reconnect the fuel and restart the car. if your carb is the front one you will have to hold the throttle arm open to run the carb out of gas.
